Replacing the Pistons
Old Jul 12, 2010 | 12:28 PM
dsddcd's Avatar
Default Replacing the Pistons
Can you unbolt the rods from under neath the car? I have been thinking about replacing the pistons and rings and that would make it much easier.
Old Jul 12, 2010 | 12:46 PM
camuman's Avatar
yeah, rod bolts install from bottom so yeah you def can unbolt them from underneath and then pull piston and rod up from above.
Old Jul 12, 2010 | 01:37 PM
dsddcd's Avatar
Perfect, I will keep you guys posted on this one.
Old Jul 12, 2010 | 01:54 PM
ChefJ's Avatar
Gonna be difficult to measure clearances from under there. GL
Old Jul 12, 2010 | 02:25 PM
camuman's Avatar
this just eliminates removing the crank to do the piston swap. you still pull the head and clearence the rings from above
Old Jul 12, 2010 | 04:19 PM
D1sclaimer's Avatar
Are you gonna hone the cylinder walls with the block in the car?
Old Jul 12, 2010 | 04:41 PM
TRBOKEV's Avatar
This in the car stuff sounds like a PITA. Taking the motor out also sounds like a pita. We are both screwed.
Old Jul 12, 2010 | 04:45 PM
JoeyBalls's Avatar
Why not just drive around with the leaky headgasket for the remainder of the summer , seems like you only noticed cause you looked for it
Old Jul 12, 2010 | 05:12 PM
TRBOKEV's Avatar
My car has been getting slower as the head gasket has been degrading. I'd rather fix it before it becomes a major failure (engine boom!)
Scott on the other hand just enjoys working on his car more than driving it.
Old Jul 12, 2010 | 05:15 PM
JoeyBalls's Avatar
^ I see, that makes sense. I am going to just have to bite the bullet and get a leakdown test done
