Replacing the starter
Old Feb 15, 2008 | 04:48 PM
CTECHs2k's Avatar
Default Replacing the starter
Hi, I need my starter replaced and im planning to do it myself. Does any body know how to and would the pipe connected to the TB need to be out??? Thanks!
Old Feb 15, 2008 | 05:33 PM
Slows2k's Avatar
Yes. Remove the charge pipe.
Old Feb 15, 2008 | 10:23 PM
nightcrawler7188's Avatar
just undo the clamps and pull out the pipe. and you dont need to take off the SC. just remove the bolt that holds it to the alternator and remove the bracket. then you should be able to do what you gotta do.
Old Feb 16, 2008 | 06:43 AM
ATOice's Avatar
Removing charge pipe would only take a minute. Do it so you have less complication.
Old Feb 16, 2008 | 06:52 AM
CTECHs2k's Avatar
So I guess doing from the bottom to the top would be harder?
Old Feb 16, 2008 | 08:43 AM
Asura's Avatar
Issue is the CTSCer bracket (assuming you have a Comptech from your handle) uses the alternator top bolt for a bracket attachment point on the driver side.
The easiest way to replace the starter is to remove the alternator first. Be very careful when removing the upper starter bolt with a u-joint as it is easy to break the knock sensor.
-asura
Ascens1on
Sep 5, 2013 06:34 AM
HondaS
Jan 22, 2008 09:36 AM
s2kkyo
Dec 18, 2007 05:16 AM
no-cones
Sep 19, 2007 08:41 AM
Sean Juan
Apr 16, 2007 02:49 PM
