Resistor box removal
Old Dec 22, 2011 | 02:01 PM
Spec_Ops2087's Avatar
Default Resistor box removal
Due to upcoming emissions test, I'm swapping in my stock injectors. Back when I got my turbo kit, no PnP injector sets existed and all were peak and hold so a resistor box was required.
I'm uninstalling the box now but I just want to make sure I'm not missing something...
It appears it was wired in what looks to be a diagnosis port of some kind - can I simply unplug the box and be good to go or do I have to reconnect the spliced wires for this port as well?
Thanks
Old Dec 23, 2011 | 11:59 AM
RedLineS2k10's Avatar
Be careful removing that. You could potentially burn out the inputs on the ecu if u run it.
Sent from my DROIDX using Tapatalk
Old Dec 28, 2011 | 08:09 PM
anarchy187's Avatar
Omfg get a wiring diagram before you touch any of that rat nest.
Old Dec 29, 2011 | 06:03 AM
siadam's Avatar
That would be ideal, but if not, just trace the wires and see where they lead and whats going on. Will help you figure out what you are messing with.
Whenever I do wiring, I always unplug the ecu/battery just to make sure I don't cross anything accidently while I'm working.
illist2k
May 10, 2017 08:44 AM
rob!
Feb 24, 2008 07:15 PM
2big4aS2000
Jan 30, 2008 12:43 PM
Venomous S
Jul 31, 2007 10:17 PM
