Return Line Question
Old Jul 19, 2009 | 08:04 AM
s2kneub's Avatar
Default Return Line Question
how is it that people situate their return lines to empty into the exhaust manifold side of the oil pan? ive tested how oil sits in the oil pan considering how it sits on the car, and with even 4 quarts of oil, oil is on the verge of spilling out of the pan on that side. i dont see how, with 5 quarts especially but even with 4 quarts, it would be possible for oil to actually drain into the pan from that side. any insight would be greatly appreciated.
Old Jul 19, 2009 | 09:01 AM
s2kneub's Avatar
btw im using a revhard log manifold...hence why tapping that side would be most effective for me.
Old Jul 19, 2009 | 09:26 AM
boostedf22c's Avatar
Don't return it into the pan, tap into it above the oil pan, in the main girdle. The piece underneath the block in the pic, on the left.
Old Jul 19, 2009 | 10:07 AM
s2kneub's Avatar
wouldnt that be a complete and utter pain in the ass to do?
Old Jul 19, 2009 | 10:17 AM
It's no harder than tapping the oil pan, it's just aluminum??
Old Jul 19, 2009 | 10:44 AM
s2kneub's Avatar
id need to remove the girdle to weld into it wouldnt i?
Old Jul 19, 2009 | 11:02 AM
m R g S r's Avatar
it is a pain in the ass only because you need a right angle drill and a reduced shank drill bit and the bit needs to be cut and re machined by a machine shop in order for the drill and bit to fit between the frame and the motor.
other than that it's just drill straight through, tap with an expensive 1/2" npt tap, and clean the shit out of everything before re-installing. espically the surfaces of where the oil pan meets the motor, to make sure there are no leaks...because it sucks to fill the motor with oil just to find there is a leak, and have to pull the pan again, wasting the $50 you just spent on synthetic oil
btw the correct sized drill bit is 45/64, but it is hard to find. my local hardware store had an 11/16 bit that was only a couple hundreths smaller. and the tap still ran through fine,
s2kneub's Avatar
and do you have a picture of exactly where it should be tapped in the girdle?
Old Jul 19, 2009 | 11:03 AM
We just pulled the pan off, and drilled/tapped the girdle with it on the car. We were able to catch all the shavings from the back side because the pan was off.
If you are wanting to weld on a fitting, that would probably be a PITA with it on the car.
Old Jul 19, 2009 | 11:05 AM
I don't have any good pics, but you can see it in this pic, it has a blue cap on it.
