Rev to 3k
Old Apr 3, 2008 | 04:09 PM
secrets2k's Avatar
Default Rev to 3k
so everything is done with my car i go and start it and it throws a check engine light and will only rev to 3k could this be cuz i dont have a bypass vavle?
Old Apr 3, 2008 | 04:22 PM
TelosHedge's Avatar
are you getting fuel cut at 3k?
i can't imagine a bpv will do this to you.
what exactly are you running? turbo? sc?
what kind of engine management? aem? emanage?
fill us in!
secrets2k's Avatar
turbo Aem but its ot tuned yet
Old Apr 3, 2008 | 05:29 PM
secrets2k's Avatar
wow 38 views and 1 person replies thanks guys!
Old Apr 3, 2008 | 05:38 PM
AusS2000's Avatar
Well until your previous post you're not really giving us much to go on.
Try telling your whole story and see if you get a better response.
When did you go turbo?
When did you install the AEM?
When did the problem start?
Throw us a bone here.
Old Apr 3, 2008 | 05:39 PM
AusS2000's Avatar
Oh, and BTW, I'm guessing not everything is done yet, and that's your problem.
jwa4378's Avatar
What is the check engine light for? I think AEM still reads those things, but they pop up for different reasons. Datalog anything yet? I think more info is needed than what you have provided. We are not psychic.
John
Old Apr 3, 2008 | 06:04 PM
Spec_Ops2087's Avatar
If you are using the AEM EMS, the CEL will not work unless its set in the software. Things like the ABS indicator / SRS light / etc will still work however and you can use the CEL to pull the code (off topic).
Old Apr 3, 2008 | 06:08 PM
secrets2k's Avatar
the aem is not hooked up yet
Old Apr 3, 2008 | 06:10 PM
kix's Avatar
kix
your car is probably shutting down once it sees boost. Are you running any EMS currently?
