the road to turbo
Old Oct 30, 2008 | 12:47 PM
  #21
passmans2kny's Avatar
your providing very good entertainment when i should be working, i love diy turbo projects, good luck with the rest of the install/ fabrication
Old Oct 30, 2008 | 12:52 PM
  #22
jzz30's Avatar
thanks
Old Jan 20, 2009 | 08:40 PM
  #23
jzz30's Avatar
after waiting several months for the machine shop to bore, hone, and linebore my block and race balance the rotating assembly i am starting to built the motor. the block is back from machining and im waiting on bearings so i assembled the rods and pistons and cut the rings. unfortunately i overcut one of the rings so i have to order some more hopefully i can just buy 1 set and not all 4
Old Jan 21, 2009 | 05:00 AM
  #24
jcoosi's Avatar
Very nice work.What rods did you use?
Old Jan 21, 2009 | 07:02 AM
  #25
GDM S2K's Avatar
they look like pauter
Old Jan 21, 2009 | 10:12 AM
  #26
jzz30's Avatar
yes pauter
Old Aug 22, 2009 | 09:56 PM
  #27
jzz30's Avatar
after much delay i finally started to v-mount my car. turns out this is a very slow project the idea behind my v-mount is that i didnt want an intercooler showing in my front bumper, and keeping a/c because hawaii is hot!
the reciever dryer's new home using pat's a/c hose relocation. no hose lengths were changed.
a little angle change of the low side line off the compressor and completely eliminating the hard line that runs along the center "beam" of the car resulted in a more ninja approach of the a/c line. again unchanged length of pat's a/c line.
everything put together and painted flat black for the added stealthness
an aluminum pannel was added to direct air through the condenser and also so that air doesnt enter through the space between the radiator and condensor causing wierd air flow resulting in overheating or a/c not very cold.
kind of a bad pic but you wont notice anything has changed by looking in to the bumper grill. all you see is the deflection plate and condensor.
a greddy bubbler tank was added and the breather valve on the intake manifold was converted in to a hose fitting for continuous bleeding and easy filling of coolant anytime the coolant need filling. i would recomend this mod to everyone just because of the difficulty some people have bleeding the air out of the engine.
an engine bay pic showing the overall setup. sadly its still NA but im getting there. next i will need to mount the intercooler core and make endtanks in the best possible shape for the piping. this pic also showing my severely modified koyo radiator for s2000.
Old Aug 23, 2009 | 11:13 AM
  #28
brendanj85's Avatar
Wow great craftsmanship wish i had the experience and patience...
Old Oct 27, 2009 | 11:48 AM
  #29
jzz30's Avatar
some new pics mock of the turbo, manifold, wastegate, down pipe and new midpipe
new clutch spec stage 3+
turbo setup:
Old Oct 27, 2009 | 12:09 PM
  #30
jari8378's Avatar
wow...
i want to learn to weld and do that kind of thing
