Rotrex C38 Kraftwerks log
Thanks guys! I was hoping people here would respond positively. I was rly happy. Hopefully I can get better fuel and retune. Man the small town I live in doesn't have E-85 for 1.5hrs away.. So I'm going to have to get a barrel..
Originally Posted by iLLap2
http://imageshack.com/a/img849/8673/aul7.jpg
After summer I'm going back at it with a high flow cylender head, use my Magnus, E-85... Those will be much bigger numbers.
Originally Posted by s2000442
Details about setup like blower model, race kit?, fuel used, injectors, intake restrictor etc. Look forward to results. Sent from my SAMSUNG-SGH-I337 using Tapatalk
BC Stage 2 cams
Supertech Dual titanium valve springs
1000cc injec / 320lph pump
ASP Custom made big tube header
Magnus high flow intake mani
Skunk2 72mm throttle body
Hondata 4bar map sensor
Clutch masters clutch
Clutch masters Lighter flywheel
Invidia Titanium exhaust
Invidia 70mm test pipe
Stoptech Rotors
Hawk pads
Defi gauges
Prolly more I can't remember
If he has the 81, can he even up the boost or is it maxed now? Switching to e85 even worth?
BC Stage 2 cams
Stoptech Rotors
Hawk pads
Defi gauges
(crank pulley)/(blower pulley) * (drive ratio) * (redline) = (impeller speed)
100mm / 70mm * 7.5 * 8 (don't know his redline) = 85,714 impeller speed.
Max speed for the c38 units is 90,000. He could up his redline to 8400 (I'd go 8300), which would put impeller speed at 90,000 and increase boost. I'm really curious about the amount of boost coming out of the rotrex unit outlet.
