S-2000 SC Problem
Old Apr 28, 2009 | 07:35 AM
Marine1's Avatar
Default S-2000 SC Problem
I have a Godzilla BOV on my 2003 Honda S-2000 equipped with a Comptech SC. When running at constant RPMs in any gear, I get a very loud chirping noise. The sound is like a bearing going bad. If I give a little throttle (i.e., a little boost), the sound stops immediately. When under high boost, there is never any sound. It also seems the chirping is louder when the air is hotter (I am running an innercooler). I tightened the SC belt but it made no difference.
When I was running a low boost pulley, I ran the blowoff back into the engine. However, once I went ot higher boost levels and added the Godzilla BOV, I got the loud chirping sound. Friends can hear it three cars back.
My question: is the Godzilla BOV adjustable so as to provide more relief capacity? If so, can you explain how to adjust the spring? Is adding more relief even the answer?
Maybe the chirping sound is not from lack of blowoff capacity. Anyone have experience with this issue?
Old Apr 28, 2009 | 06:52 PM
s2k aok's Avatar
i got loud pterodactyl sounds on my other supercharged car (mp62 roots hybrid blower) and the cause was either a loose belt or a bad pulley tensioner.
oldskooleskimo
Mar 22, 2012 03:45 PM
s2konroids
May 1, 2010 06:45 AM
Marine1
Apr 29, 2009 12:53 PM
stena
Mar 20, 2009 05:27 AM
