S/C installed
Old Dec 30, 2005 | 11:08 AM
Trip's Avatar
Default S/C installed
I am finally Supercharged
Comptech Kit with Aftercooler, 7Psi pulley, Tech2 FMR for A/C and Gozilla BOV. Tuned with Emanage.
few questions
1)After my engine warms up (3 bars) and give it the first run to redline i get slight hiccups (not bogging)just after 6000rpm up to redline.
the strange thing is it only does it on the first run.
2)Peak boost reading is not always constant at redline. the max i saw was 6.9psi and min was around 5.8psi. Is this normal ?
i still need to replace my plugs (currently running IK22). Had to order them from US since i did not find any local NGK 7173.
Thanks
Old Dec 30, 2005 | 11:25 AM
xviper's Avatar
My Vortech does something similar (not quite the same). During the first warm up stage, if I'm just running at steady state with very slight changes in rpm, the engine will have a single "hiccup" between 3000 and 4000 rpm. Like you, it only happens after the first cold start of the day and only once. If I accelerate briskly past that rpm and don't let it hang around in that area till after the engine is up to operating temps, I can prevent it from happening at all. I attribute this to the MAP clamp cutting in the first time as the boost becomes significant. Perhaps your Comptech is similar but manifests itself with a slightly different symptom.
Did you solder all your ESM connections? Comptech seems to be very suseptible to crimp connections.
As for your variable boost reading, perhaps you have a slight leak in one of your vacuum/pressure lines. I've seen reports here that having a single dedicated vacuum line (with no "T's" in it) for the FPR will help to produce a more stabile a/f ratio when in boost. Perhaps having fewer "T's" in any given line will also help with a more steady boost reading from your gauge. My boost reading is rock solid and is the same every time at redline.
Old Dec 30, 2005 | 05:35 PM
Trip's Avatar
[QUOTE]My Vortech does something similar (not quite the same).
Old Dec 31, 2005 | 06:09 AM
xviper's Avatar
Originally Posted by Trip,Dec 30 2005, 08:35 PM
Having separate lines one for FPR and the other for boost reading will require a new fabricated "nipple" on the manifold.
You can take vacuum/pressure feed from several places on the intake manifold. that one that Comptech chooses is only one. Any of those rubber hoses going across the manifold can be "T'd" into. However, if you use the PCV line, you should put on a vented catch can first.
I can't help you with your other question.
Old Jan 7, 2006 | 05:45 PM
Trip's Avatar
I probably found out why my boost is not always constant at a specific rpm. I did some runs in the afternoon and was getting constant 7.4psi at 9000, late at nigh a was getting 6.6psi. Humidity
Old Jan 9, 2006 | 09:09 AM
stitos2k's Avatar
Whats humidity I haven't seen any since December. Might as well be the desert here.
Old Jan 9, 2006 | 11:49 AM
Trip's Avatar
I don't know there but here its currently 93% humid.
MrJohnnyLy
Sep 11, 2013 05:53 AM
JamieP
Jun 1, 2012 07:21 PM
bimmerpowa
Mar 20, 2007 08:01 PM
yiannakos
Feb 22, 2007 02:44 AM
frans2k
Sep 28, 2004 11:47 AM
