S256 plus water/meth?
If you search in the FI section only, there was a huge water/meth thread with some really good info. I know Joey, Siadam, Omalley, External and some others used meth with vary degrees of success. I think the power chart also shows if someone was using pump/meth to get their numbers. The power chart is a sticky on the top of the FI section.
I used it on my old comptech high boost sc setup, tbh it didn't offer much in the way of power running a 50/50 mix but dropped iats by 25c.
I managed to get around 1 degree advance in timing which on my setup yielded power but not loads.
On the comptech after I taped a hole right at the end of the straight bit near the camber to give it dwell time to mix. I used an aem kit.
Originally Posted by JUSTINTHECOASTIE' timestamp='1384222469' post='22872705
40/60 ain't too bad either meth/water
Not sure what a s256 equates to, but my tuner told me that 500hp with a 50/50 meth mix would be "no problem" on a conservative tune, using a gtx3582r. Only a single nozzle, pre-TB with an aquamist kit. Hasn't gotten dyno'd yet, but when it does, I'll post up the results.
