S256 plus water/meth?
Old Nov 13, 2013 | 04:58 AM
  #31
camuman's Avatar
Tune on pump gas first and see what it makes. Meth gets more people into trouble then it helps.
Old Nov 13, 2013 | 05:26 AM
  #32
lude92_si's Avatar
The only problem there is my tuner is over 10 hrs away. So I need to install the kit before I go to the tuner. I already know he doesn't want to go much over 450 on just pump. The Guy that had this kit before me was around 470 I was told. I would be happy with that but would really like to break 500whp.
Old Nov 13, 2013 | 11:44 AM
  #33
camuman's Avatar
on pump gas with a smaller snail hard to hit same numbers as guys with bigger snails. smaller snail more heat. meth,water will help. i ran 50/50 in my sc. also ran straight water. you can run water only and it will cool the charge just fine. but you wont gain the octane that meth provides. just dont rely on it to run a shit ton more power then you can on pump. again, i would tune on pump to max what tuner says he can extract. meth gets old and can be dangerous. so many horror stories on the site. my current setup belted out 450 on pump and i was happy. i sold the meth kit and never looked back.
Old Nov 13, 2013 | 02:29 PM
  #34
lude92_si's Avatar
I may just have to order E85 by the drum. I'm guessing I would have to change my fuel pump out but would ID1000 be enough? I want room to grow down the road. Anything else needed to run E85?
Old Nov 13, 2013 | 03:06 PM
  #35
d-bo's Avatar
You can run id1000's and pick up an e85 walbro pump (4xx lph) I just put one in my evo. It's super quiet compared to a 255 too
My car made the power it made because it had about 15-20 degrees of timing into it more than any other map I've seen on 93oct. And that was the map AFTER it blew up so I am sure it had more in it before I took the car back.
I would expect probably 440-450hp on 15psi easy.
I think e85 would really be your best bet if it isn't your daily driver in the summer
Sent from my iPhone using Tapatalk
Old Nov 13, 2013 | 03:50 PM
  #36
lude92_si's Avatar
No its not a daily its a 2000 had 14k miles on it at the start of summer. Its a summer car and a few trips to the strip. I think e85 would be the safer route. I haven't ordered injectors yet but was about to get a set off id1000. I could go bigger if needed tho. Research time . Thanks dbo for your help so far.
Old Nov 13, 2013 | 05:37 PM
  #37
p0staboy's Avatar
Did you have direct port or single
Old Nov 14, 2013 | 04:13 AM
  #38
boostedf22c's Avatar
Originally Posted by baZurk
Joey, haven't you mentioned before that it is possible to just spray water through a single port on the charge pipe? Does that benefit the motor at all?
This is what I did when I drove my car everyday. Ran a single nozzle AEM kit and ran a 50/50 mix of M1 and distilled water. Went 9.9 @ 141 on it running 93 octane and made 680whp.
Old Nov 15, 2013 | 04:05 AM
  #39
lude92_si's Avatar
Was looking at Cooling mist kits those look pretty solid with some good failsafes. Anyone use there products?
Old Nov 15, 2013 | 05:12 AM
  #40
baZurk's Avatar
M1?
