s2k no more!
Dude I really did just cry when I scolled down to the pictures. Why did you have to post them
. The first thing that came to mind was an oil leak as well, as posted above ^. Have you found the cause? I wish the best of luck to you man
ya i think i found out the problem! hopefully not positive but like you all were saying oil leak! my waste gate is obviously below right below the manifold cause i have a top mounted turbo. the dump-tube is close to ( i would not say that close but close enough) to the oil drain line that goes from turbo to the oil pan... Scottie said i was shooting flames out my exhaust so i assuming that maybe the exhaust from the dumb-tube broke the oil line going 2 the oil pan!
thanks for all the support again guys!!
ya i was thinking about parting it out depends on how much insurance wants to charge to buy it back!
parts list real quick just so you guys know!
the exhaust wrap is still on the downpipe ha
full exhaust test pipe and cat (invidia)
the rear taillights (2004)
oem spoiler, trunk lid and side flairs or skirts
rear dif
i dont know about the trans
the turbo is fine just may need a new bearing
the back rims were never touched tires still on and great shape
the front rims are good but need paint work
everything else is gone!
ill let you guys know if i have a par tout thread
thanks
rear dif
thanks
That's sad man. Anytime a S2000 bites the dust is one less cool car on the road!
Luckily there are still plenty around, and prices have come down a lot over the last year, so you should have no problem finding a good one to replace your baby.
Hopefully you'll get things straighten out and will be working on your "new" S soon. If you like wrenching on you own car, then you can look forward to working on it
As everyone has recommended, make sure you use steel braided hoses for all your oil lines and heat shield anything close to the turbo. Another good investment is to have the header ceramic coated. Although, coating cracks on some headers like the FR due to the fact that they expand/contract alot due to heat cycling. Cast headers should do better.
Looking forward to your new S project soon !
I hope you can get another one soon!
