S2k Turbo
Old Nov 3, 2009 | 03:30 PM
s2k?'s Avatar
Default S2k Turbo
Ok So going to be buying an s2000 after this winter and was wondering what kind of work needs to be done to the car before you turbo the car?
Old Nov 3, 2009 | 03:34 PM
g352s2k's Avatar
depends what turbo setup you are trying to do.... there are a lot of threads of our stock motor holding up to 700+ hp. If your looking for only 300ish hp greddy is pretty much plug and play. All you need a walbro pump. If you want more power more work needs to be done, like clutch, head work, maybe head gasket etc etc.... i'm still a noob at this and all this info can be found using the search.
Old Nov 3, 2009 | 03:47 PM
s2k?'s Avatar
Yeah i prob only going to want maybe 300+ maybe nothing too much. not looking to go up and down the road racing every kid. maybe a track run (not drag) every now and then. I looked at the greddy kits and did a little research on it. dose seem to be a plug and play. But just making sure cause cant afford to replace the hole motor once i buy this car. S2000 + a 97 accord for winter
Old Nov 3, 2009 | 03:51 PM
g352s2k's Avatar
I've been trying to tune the greddy by myself a little while I get all the other stuff done meth, exhaust, other stuff. I love the greddy but you want to make sure you don't want anymore power then around 330-350 hp. Plus the greddy kit is so cheap now and days you can get one new for 3000 shipped.
Old Nov 3, 2009 | 03:56 PM
s2k?'s Avatar
Well if i do the headers and if i get the turbo should i do a turbo back exhaust maybe and a couple other things that dont do much to the Hp that be fine to the greddy right?
Old Nov 3, 2009 | 04:05 PM
JoeyBalls's Avatar
its a "header" and you will take it off when you go turbo and use a "manifold"
Old Nov 3, 2009 | 04:21 PM
g352s2k's Avatar
Yeah... no header with a turbo. From what I read a high flow cat is best asura makes high flow cats with two bungs one for your o2 sensor and one for the wideband. And just get a catback exhaust. Take a look bat the utimate greddy thread lots of info there. And if you ever want to upgrade look at joeyballs thread.
Old Nov 3, 2009 | 04:28 PM
s2k?'s Avatar
ah ok thnaks this is pretty helpful.
Old Nov 3, 2009 | 04:56 PM
JDMallmotorAP1's Avatar
a healthy motor
Old Nov 4, 2009 | 04:26 AM
s2k?'s Avatar
Yes healthy motor but define a healthy motor.
