s2knoob's Turbo Build
Old Jun 27, 2012 | 05:29 PM
  #101
manny-s2000's Avatar
Originally Posted by s2knoob89
Originally Posted by manny-s2000' timestamp='1340839424' post='21816904
How do you find the heat without coating or wrapping the manifold man? I think I may do the same thing with my dumppipe and dumptube.. Is that just wrap on it or did you get it coated before wrapping?
I may spray my dumppipe/tube in dei exhaust paint prior to wrapping. Will that give a positive or negative affect with heat and rust?
The sidewinder gives off alot of heat but my hood is vented, lines are wrapped and wires are all tucked so it's not really a problem. Down pipe is just wrapped. If your parts are made from stainless you really don't have to worry about rusting.
thanks for the response man.. If you don't mind where did you buy the heatwrap fOr the wires and downpipe? They seem to be holding up fine!
Old Jun 27, 2012 | 06:42 PM
  #102
s2knoob89's Avatar
Originally Posted by s2knoob89' timestamp='1340843378' post='21817027
[quote name='manny-s2000' timestamp='1340839424' post='21816904']
[/quote]
Got everything from summit racing. All DEI products.
Old Jun 29, 2012 | 11:39 AM
  #103
pqbrown's Avatar
Originally Posted by pqbrown' timestamp='1340834229' post='21816663
How tough was it to fit the oil line there by the cross member?
Oil feed was easy no problems at all. Drain required me to notch the crossmember a little at the outlet flange.
So all you had to do was the minor degree of notching listed on the first page? Seems to be mild, is that the case? Considering your exact set up 6262 with the PLM mani/dp. Any suggestions or things to look out for other than notching?
Old Jun 29, 2012 | 12:22 PM
  #104
s2knoob89's Avatar
Originally Posted by s2knoob89' timestamp='1340834573' post='21816689
[quote name='pqbrown' timestamp='1340834229' post='21816663']
[/quote]
I actually had to notch the crossmember about another inch to the right for more clearance but that is it. Once you have everything bolted up it's easy to see where the crossmember needs to be cut.
Old Jun 29, 2012 | 03:17 PM
  #105
pqbrown's Avatar
Thanks for the prompt replies. Do you feel the manifold is solid? It almost seems too good to be true for the price.
Old Jun 29, 2012 | 04:12 PM
  #106
s2knoob89's Avatar
So far so good but if it starts to crack you guys will be first to know.
Old Aug 17, 2012 | 01:37 AM
  #107
s2knoob89's Avatar
Vid for you guys! SC300 has a JDM 2JZ swap spraying water/meth. This would have been a much closer race if the fawkin Cobra would of lined up and I actually got to brake boost. Oh well I think a water/meth setup is in my near future.
http://www.youtube.com/watch?v=kjv0WupFQqE
Old Aug 17, 2012 | 02:16 AM
  #108
riceball777's Avatar
very close race
Hows that manifold holding up? Any cracks yet? How many miles do you have on the setup?
Old Aug 17, 2012 | 02:58 AM
  #109
s2knoob89's Avatar
Originally Posted by riceball777
very close race
Have around 4500 miles on the setup and the manifold is still holding strong.
Old Aug 18, 2012 | 05:13 AM
  #110
Killer_B's Avatar
Do you have any of the following problems:
1) having to crank the motor a lot before it starts?
2) battery not charging whenever you use the car?
3) engine cranking slow when starting?
