Is it safe to fun 7psi pulley w/ stock injectors?
Is it safe to fun 7psi pulley w/ stock injectors? thinking of getting 7psi pulley and tune A/F and timing with e-manage. do you think is a safe setup? hope you can give me some opinions. thank you!
It would help to know what your running
I'm assuming a comptech SC. If thats the case then yes, the general concensous is that the stock injectors will go to about ~350ish hp. 7psi will stick you around 305hp so your still good.
