SC
Old May 25, 2010 | 05:00 PM
SeanSerino's Avatar
If you're buying new, I would recommend the Science of Speed kit. If you're buying used, Comptech or Vortech are pretty much the same, in terms of power.
New kit ~$5000+
Used kit ~$3000
A kit will get you ~300whp at 6psi.
Get an AEM EMS and get it tuned ~$1900
High boost pulley ~$100
Injectors ~$300
Wideband for tuning ~$200
Running high boost, you will want either an aftercooler kit (unless your SC kit includes it) or a front mount intercooler set up. ~$1000, cheaper used
Theres going to be a lot of other smaller things that you'll need to replace along the way, but that is the basics of what you'll need. Not sure what the total would be, but for 400whp, expect to spend at least ~$7000.
Get a used kit ~$3000, slap it on, and have some fun. When you get used to the power, spend another ~$3000 for the tune/EMS and run high boost (12-14psi) and you'll have close to 400whp. That's my plan anyway. Just had my Comptech kit installed, loving it, but I have a goal of 400whp.
Old May 25, 2010 | 05:01 PM
SeanSerino's Avatar
Also, you can free up a lot of power by running an aftermarket header, hi flow cat, and exhaust. So that's another $1200+, at least. Twice that if you want JDM parts.
Old May 25, 2010 | 05:05 PM
DeadZero's Avatar
you got A LOT of searching to do hommie. obviously you havn't searched if you at first believed that there wasn't an s2k with more then 10lbs of boost.
search supercharged
Old May 25, 2010 | 05:18 PM
Houston'sS2kchris's Avatar
[QUOTE=DeadZero,May 25 2010, 05:05 PM] you got A LOT of searching to do hommie.
Old May 25, 2010 | 06:00 PM
Well thanks for all the help as of right now its looking like when I can do it it will be Science of Speed kit............ but trying to decide on weather keep the motor stock or go ahead and build me an engine for reliability and durability ? any suggestion
Old May 25, 2010 | 06:14 PM
96-EJ6's Avatar
The stock motor should be fine unless you have some SERIOUS power goals. The stock motor is very stout and will produce great power, BUT tuning is everything! Just be sure if your planning on running high boost you have the supporting mods, ie. Fuel pump, injectors, good engine management, free flowing exhaust, ect.
SoS Stage 2 with K-Pro/FlashPro gets my vote, but all the kits on the market work well.
Old May 25, 2010 | 06:21 PM
daicacharco's Avatar
Just spend a good entire day reading on the forums. You will find a lot of information upon peoples build threads.
Old May 25, 2010 | 06:22 PM
why is the K-pro better then the EMS ?
Old May 25, 2010 | 06:28 PM
96-EJ6's Avatar
I'm not saying it's better (that's a whole thread by itself), it's just what I have more experience tuning, and the interface is much more user friendly.
What year is your car?
Old May 25, 2010 | 06:37 PM
2003 So would you recommend it for mine or the EMS same performance wise
