Setting alarms for serial gauge
does anyone know how to set alarms on the aem serial gauge?
For example the gauge would beep/blink when i reach operating temp, or when im going through the gears it would beep/blink when i hit 10psi.
I figured it out by reading through the forums on AEM's website.
It's very cool once you get it. It's too bad the software isnt as user-friendly.
The problem is you can't have one gauge setup that works for any s2000 because you need the values that your specific AEM EMS is sending out in order to calibrate the gauges correctly.
That is true, but I'm sure you could slightly alter the settings to make it work for any S2000 rather easily. Would you mind sending your calibrations my way? I have dicked around with mine a bunch but havnt mastered it yet, and starting from scratch for IGN timing and other useful gauges will take a long time
Originally Posted by dammitjim,Nov 29 2009, 01:07 PM
A step by step diy on programming this thing would be great.
Druz do you have links to the threads on the AEM site?
AEM Forums
Originally Posted by RAIN H8R,Nov 29 2009, 01:16 PM
When you install this thing what is needed other than the serial connection? Power and illumination?
