Sideways on the dyno
Old May 30, 2015 | 08:21 AM
  #21
killerbee_vr6's Avatar
Let's not forget the church dyno correction factor
Old May 31, 2015 | 06:54 AM
  #22
Sideways's Avatar
Originally Posted by KaNgArOo
Another reason why he might be able to run 91oct is because he isn't seeing full boost until redline since it is a centrifugal supercharger.
Think about this: more boost than others at much lower rpm.
Originally Posted by Spoolin
Nice! I bet if you lower your VTEC to around 3600 rpm, you may be able to get that dip out. Have you played around with moving the VTEC either way to see how it does to correct the dip?
Vtec is currently set at 3600 rpm.
The 25 psi of boost was obtained with an impeller speed of about 59,000 rpm. The Mustang crowd is spinning the T-trim to speeds of 65,000 to 68,000 rpm in the quarter mile.
All I need to see 650 rwhp is a few thousand dollars.
Old May 31, 2015 | 12:33 PM
  #23
blixhavn's Avatar
impressive sideways! I wanna see you hit 650 with a charger, that would be awesome!
Remember me from 4 years back or so, you took me for a ride while I was at a tournament in HB?
Old May 31, 2015 | 01:32 PM
  #24
tom153's Avatar
Very interesting! I'm planning on spinning mine up to 60000 with a 3.2" pulley and was expecting 20-22psi
Old May 31, 2015 | 02:10 PM
  #25
Sideways's Avatar
Originally Posted by blixhavn
impressive sideways! I wanna see you hit 650 with a charger, that would be awesome!Remember me from 4 years back or so, you took me for a ride while I was at a tournament in HB?
Are you still doing paint ball? Still have your S?
Old May 31, 2015 | 02:12 PM
  #26
Sideways's Avatar
Originally Posted by tom153
Originally Posted by Sideways' timestamp='1433084077' post='23630893
[quote name='KaNgArOo' timestamp='1432944529' post='23629652']Another reason why he might be able to run 91oct is because he isn't seeing full boost until redline since it is a centrifugal supercharger.
Vtec is currently set at 3600 rpm.The 25 psi of boost was obtained with an impeller speed of about 59,000 rpm. The Mustang crowd is spinning the T-trim to speeds of 65,000 to 68,000 rpm in the quarter mile. All I need to see 650 rwhp is a few thousand dollars.
[/quote]
Watch your intake temperatures. The S trim at that speed blows hot.
Old May 31, 2015 | 09:59 PM
  #27
tom153's Avatar
I'm running a V1 T trim with HD bearings
What are your IATs at these boost levels? Mine are 115-ish at ~16psi on 80-90 degree days.
Old May 31, 2015 | 10:57 PM
  #28
Sideways's Avatar
I don't remember the IAT but it didn't spike.
Old Jun 1, 2015 | 06:29 AM
  #29
MikeThorne03's Avatar
Any videos of the car ?
Old Jun 1, 2015 | 11:09 AM
  #30
Sideways's Avatar
Here is an old one: http://www.streetfire.net/video/tts-...ere_149854.htm
