smaller ac condenser?
Old Jun 1, 2014 | 06:11 PM
Monacos2k's Avatar
Default smaller ac condenser?
I was wondering if anyone has put a smaller ac condenser in there turbo s. I was wondering because I was thinking of putting a condenser out of a del sol or civic so I can get better flow through the intercooler and through the radiator. I don't care much if my ac is super cold just don't want to delete ac. Wondering what you guys think and if its a bad idea. Thanks
Old Jun 2, 2014 | 06:20 AM
Monacos2k's Avatar
Also my current condenser is pretty beat up from road debris and feel like its blocking even more are to my radiator. Any comments or suggestions would be aprriciated.
Old Jun 2, 2014 | 06:24 AM
baZurk's Avatar
SOS seems to have a a/c condenser solution with there new vmount intercooler and radiator setup. I would contact them. I'm not sure if it is smaller or relocated and if it can be used with a traditional intercooler/rad setup but it would be worth a phone call.
Old Jun 2, 2014 | 07:36 AM
Monacos2k's Avatar
Okay thank you I will look into I also have a koyo radiator. I just don't know if it would fit with the v mount setup but I will research a bit on that. Thank you again.
Old Jun 2, 2014 | 08:00 AM
dduaime's Avatar
A smaller condenser will increase pressure ac system, which is not too good for all parts.
Old Jun 2, 2014 | 08:09 AM
Monacos2k's Avatar
So will the increased pressure in ax system only affect the ac parts? I don't ever use the ac would just like it to still work. Could I charge is less to get less pressure?
Old Jun 2, 2014 | 08:53 AM
dduaime's Avatar
Yes, will affect only a/c part (compressor, hose, evap...)
No, less charge = no cold
Old Jun 2, 2014 | 08:58 AM
Monacos2k's Avatar
Okay would it blow out seals and such? Also what about a diffrent sized pullly on the compressor? Would that change how much pressure the compressor makes?
A. Dos Santos
Nov 29, 2016 09:06 AM
JspecVtec
Jun 1, 2011 07:03 AM
folex187
Feb 13, 2006 04:51 AM
gusrock77
Jan 22, 2006 04:27 PM
f20kills
Jun 7, 2005 11:29 PM
