Smaller SC pulley to compensate for altitude?
Old Dec 20, 2006 | 04:16 PM
waltk88's Avatar
Default Smaller SC pulley to compensate for altitude?
To counter the effects of lower air density at altitude, can I simply swap the standard pulley that comes with the Comptech kit for a higher boost pulley? To maintain the sea level performance of an AP2 with the standard Comptech set up, what diameter pulley would I need at 5000ft elevation?
Old Dec 20, 2006 | 05:22 PM
CourageOO7's Avatar
So long as you make sure your AFR's are okay by going to a tuner I suspect putting a 7lb pulley on there would be as fine as it is anywhere else. I wouldn't go higher than that without an EMS of some sort.
GL!
Old Dec 20, 2006 | 08:58 PM
gomarlins3's Avatar
I went with the 7 lb pulley from the start and I am at 2600 feet. I don't know if it 'compensates' for the altitude per say. Anything else you will be driving at that altitude will be dealing with the same problem.
I can tell you this; on the drive during SacS2KDays V, my car felt awesome at sea level. I loved it. Then I found out the great equalizer- altitude. At Mt. Rose (10,000 ft.), my car felt like it was having a hard time breathing, but I was still faster then the other S' that wanted to run when we got to the freeway.
Old Dec 21, 2006 | 12:33 PM
waltk88's Avatar
I'm thinking about trying a 3.5" pulley. I'm guessing that it will be good for only 7psi or less at 5000ft.
Old Dec 21, 2006 | 05:50 PM
CourageOO7's Avatar
Yeah, FI cars tend to cope better with altitude but you'll still lose plenty if you're way up there...
macdaddies911
May 13, 2014 08:30 AM
TheBigShow
Sep 2, 2009 08:11 AM
NFRAP1
Socal Swap Meet
Apr 30, 2008 12:27 PM
NFRAP1
Apr 30, 2008 12:26 PM
dustinmallen
Feb 4, 2007 07:26 PM
