SMOG & CTSC
So i have a CTSC non-After and im running it at 7psi i juts put the cat back on and im getting ready for smog but i dont think it will pass i was wondering if i could adjust the fpr to a certain psi and remove the belt will they smog me as a reg S2k?? well also have to turn off my Emanage U
no it won't pass,
Put your STOCK CAT back on, stock exhaust, If you changed the injectors put the stock ones back on. i think your fine with 7lbs but remember the s/c is supposed to be stock with 5lbs so you might have to switch to the smaller pulley.
Ya smog is a B@##% in California
snwbrderphat540
May 26, 2015 02:11 PM
