smoke at boost
Old Aug 11, 2009 | 09:22 AM
combats2000's Avatar
Default smoke at boost
any of you running a restrictor?
just curious.. if so what size?
im trying to trouble shoot my smokeing problem.
thanks
Old Aug 11, 2009 | 01:09 PM
s_d2k's Avatar
i use a garrett t3 60-1 journal.
at first i didnt used a restrictor but the car was smoking bad under wot.
then i put a restrictor on it , size 1-1.5 millimeter , bigger then the gt series restrictor.
it helped a lot but still smoke very little under wot.
i think that the oil is not so good also (10w30) so i got some motul 300v 15w50 and im going to try it and see.
and im also need to check the oil drain to my pan and see maybe thats my problem.
what u did with your turbo ? fixed it??
Old Aug 11, 2009 | 01:56 PM
killabee's Avatar
I run run the same(60-1) and use a restrictor and have no issues.
Old Aug 11, 2009 | 03:09 PM
hmm i never used a restrictor becasue i heard your only suppose to use it with a bb turbo?
Old Aug 11, 2009 | 03:13 PM
i have a t3/t4 percsion turbo.
it smokes after wideopen throttle between load..
im making adjustments to the drain and adding a small restrictor.
all this smoke.. I havnt driven it much thought to be honest. dont want to damage it.
Old Aug 11, 2009 | 03:16 PM
http://www.godspeedproject.com/store/index...products_id=379
i just bought that, that is a restictor set up.. going to give it a shot.
Old Aug 11, 2009 | 03:34 PM
RAIN H8R's Avatar
I thought it was common practice to use a restrictor with any turbo.
Old Aug 11, 2009 | 03:55 PM
s_d2k's Avatar
yes but the thing is that in our engine the the oil pressure is higher then other motors.
i will do the oil change and see if it helps.
Old Aug 11, 2009 | 04:32 PM
Revenge's Avatar
I have been mentioning this in various thread, I really think you need one cause the oil pressure is so high and I think you can blow the seals on the turbo even at start up with out the correct one.
Old Aug 11, 2009 | 04:48 PM
well i just bought that... not sure what size restrictor it is...
anyone know what size restrictor i should start with>?
