snow performance meth kit, good or not?
Old Feb 4, 2011 | 08:02 AM
jermocaleb's Avatar
Default snow performance meth kit, good or not?
i was looking through modified mag. and saw the advertizement for the company and looked them up, thier stage 2 boost cooling kit was developed to add more meth through how much boost you run. has any one used one? would it perform well with a greddy kit with 12psi? noob question maybe, but i have never used meth ever.
Old Feb 4, 2011 | 08:50 AM
s2000Junky's Avatar
I'm familiar with the company but not the kit. Is it a progressive type, single/double stage, multi port, pulse type? What are the specifics on how it provides more meth? Through a larger nozzle and meth ratio what?
And just from my understanding, Greddy’s get real hot when pushed up to those boost levels. More water in the mix is usually recommended, not more meth.
Old Feb 4, 2011 | 09:45 AM
svencarlson07's Avatar
my friend runs this companys kit on his sti, he says its an amazing setup
Old Feb 4, 2011 | 09:55 AM
s2000Junky's Avatar
Well the company makes quality stuff no doubt. But there isnt one type of kit that works the best on everything.
Old Feb 4, 2011 | 10:12 AM
siadam's Avatar
If you are running a greddy turbo, you don't need to spend alot of money on a high dollar methanol kit.
I think something like an aem kit would work just fine. I'd look in the 4sale section and see if you could find one for cheap...
Old Feb 4, 2011 | 11:06 AM
s2000Junky's Avatar
I'm selling my AEM Meth controller $50. You will need to pick up a 1 gal tank from any injection company with the low level switch, or modify your wiper fluid tank, a Sureflow pump or the like and order the injector kit. Summit Racing sells all this stuff. Then wire in the controller. I've got install directions included. This rout will cost you less then $300
Old Feb 4, 2011 | 12:49 PM
siadam's Avatar
I was being factitious, I'm selling my entire kit, sans the tank.
Old Feb 4, 2011 | 12:55 PM
berlinas2k2's Avatar
The greddy kit is pretty weak in terms of s2000 turbo kits, with no room to grow.
If you are craving more power, I'd suggest a new manifold and larger turbo if you're on a budget. If not, scrap the entire turbo kit and get something with a 30R or 35R for the 450+ HP
Old Feb 4, 2011 | 01:43 PM
s2000Junky's Avatar
Oh ok
What are you moving to?
Old Feb 4, 2011 | 07:04 PM
jermocaleb's Avatar
sorry i was actually talking about with a 3076r on the greddy kit. i just wanted to run it a little safer but thanks for all of the input i really apreciate it guys
