Somebody help! EDIT: SOLVED
I found out the problem...You have to be running the F20 Basemap. I have an '05 which is a F22c...but for some reason you have to use the F20.
Wow what a headache over something so dumb. Glad this is over
I was going to run off the base map because I was low on cash...but I decided to just get the tune...good thing I did because I wound up with some okay numbers. With a 60mm invidia tp, 60mm tanabe concept g dual, greddy profec b spec 2 BC and greddy rs bov...327whp and 227.5 tq at about 10.5psi. Oh yeahh the tune was well worth it.
that just sounds odd to me and glad you discover your issue.
can you post up your dyno graph with a/f and boost?
great numbers by the way
What do you have your boost controller set at? I don't have one and my car is at 8psi from take off to about 5500. About 57 it goes to 9psi, 6000 it's at 10 stays steady for a bit, then at about 65 is takes off again and goes to 12 to 13psi by redline.
I guess I need to get one, but my tuner tuned around it. If I was to turn the boost up to a steady 10 down low would it creep higher than 13psi by redline?
