Somewhat custom build that started with a manifold
Don't have any major updates for you guys, I have mostly run into problems lately. Got a new pic of the enginebay under "cable work".
Got an oiltemp sensor into the oil relocation kit.
The problem I have is about the modified fuel system. I started a separate thread about it and would be very happy for some help that can get me in the right direction. The link to the thread below.
https://www.s2ki.com/forums/index.php?showtopic=693996
The idea with the intake was to recreate the way the stock car takes air, not the air that comes though the IC and radiator. If it is a bad idea and works bad I just remove it.
About the manifold I will have to test the car and see what the minimum charge pressure is. If its creeps to a value that is under an acceptable boost level, I should be safe right?
Example: At 9k rpm the car will creep to 11 psi minimum, got a 7psi spring in the wg. I then just set up the electronic boost control so that i charge 12psi from spool to redline. That should work right?
Just wanna mention that I test started the car today, just to see if all seemed OK. The fuel pressure can only be regulated up to 56psi, but that problem I think I can solve soon. Just let it idle for a min or two.
The turbo is kinda loud, i can hear it spinning very well with a high pitch sound at idle, and it spins several seconds after the car is turned off. I remember the same sound from the previous setup with the same turbo, I suspect the condition is not 100%. Is it normal that you can hear the turbo spin to a stop after the car is turned off?
Nice to watch your progress, keep it up.
Cheers,
-- Chris
