SOS 1200 install instructinos
Old Aug 31, 2014 | 09:35 AM
EK9MAX's Avatar
Default SOS 1200 install instructinos
Just looking for install instructions.
Actually looking for how to tighten the belt. I think i'm doing it right, but it seems to keep loosening off.
Thanks!
Old Aug 31, 2014 | 10:24 AM
99SH's Avatar
It's very simple. Loosen the bolt on the tensioner idler pulley, adjust the 14mm adjuster to tension the belt then re-tighten the idler pulley bolt.
Old Aug 31, 2014 | 01:02 PM
starrman's Avatar
I used to use a small pry bar and kept the tension on while tightening up the bolt...one of those 14mm ratchet box end wrenches will serve you well.
Old Aug 31, 2014 | 03:17 PM
jsenclosure's Avatar
You don't need a pry bar with the SOS kit
Old Aug 31, 2014 | 04:38 PM
CoolGuy094's Avatar
Randy you're thinking of the Comptech kit's tensioner. That's how I do my Comptech kit too.
Old Sep 1, 2014 | 08:57 AM
hockeylfe11's Avatar
does anyone know if SOS charges for the install instructions or a basemap for one of their kits?
I'm buying a used kit
Old Sep 1, 2014 | 09:33 AM
lleron's Avatar
They told me to send an email requesting a basemap after calling them/buying a new novi 1200 blower from them and I never got a response (after a week and a half)... I wouldn't rely on them for a basemap.
I believe their kit also copies all of the Comptech kit mounting locations, so the comptech instructions should cover the install of pretty much everything besides the tensioner, which is a different design.
Old Sep 1, 2014 | 12:35 PM
EK9MAX's Avatar
Ya I loosen the tensioner pulley, then use a 14mm to tighten it.
Then re tighten the 17mm tight again.
Doesn't seem to to the trick.
Old Sep 1, 2014 | 03:22 PM
99SH's Avatar
What is the issue exactly? Is the tensioner nut loosening under vibration? If so, take a look at nord-lock washers.
Old Sep 1, 2014 | 06:50 PM
EK9MAX's Avatar
It just seems that when I tighten the belt. Go for a dive. Come back and it's loose ish again.
I didn't do the install so I'm really not sure how to tighten it.
I'm going to need some very detailed or visual instructions. I really don't know if I'm doing it correctly.
The tensioner pulley is the one below the top pulley right?
