SOS 1200 install instructinos
It should be TIGHT, as that's the only bolt holding the tension in place. The only time the tensioner pulley bolt is loose is when setting belt tension.
Edit: Per SOS, the torque on that nut is 31 ft/lbs. I do mine hand tight, as I've stripped those threads before.
So it doesn't matter how much I loosen it when setting tension?
Suzuka_Joe
Nov 16, 2014 01:31 PM
General Kratos
Jul 10, 2006 01:35 PM
jmrobins
Mar 5, 2004 05:36 PM
