SOS etc TB
Old Feb 21, 2010 | 05:25 AM
s2konroids's Avatar
Default SOS etc TB
Is it worth fitting a Tappered 70mm->64mm TB to a stock'ish SC setup 7psi like SOS, RPM etc?
I'll be running 7psi, AC, TracySports header, 5zigen singlepipe, Comptech fpr and VAFC2 - this is just to begin with.
But i wonder about the performance differences? and maybe the above setup will too much to handle fueling wise?
I read 10BHP at the wheels but is this really true and applicable for my setup?
Thanks
Old Feb 21, 2010 | 09:45 AM
camuman's Avatar
i wouildnt worry about it personally right now. if you want 10hp, up the boost 1-2psi
i would worry about injectors + standlone + more boost before i did a TB
Old Feb 22, 2010 | 12:45 AM
s2konroids's Avatar
Ok thanks, I won't be upping the boost
anytime soon though.
Anyone else care to Chime in?
Old Feb 22, 2010 | 11:48 AM
ScienceofSpeed's Avatar
Former Sponsor
Our throttle body has been independently tested to produce over 10 wheel horsepower on even standard supercharger setups. It is probably the best $/hp mod you can accomplish. Here is some further information:
https://www.s2ki.com/forums/index.php?showtopic=763911
regards,
-- Chris
Old Feb 22, 2010 | 01:31 PM
s2konroids's Avatar
Chris would these increases apply to my setup (above) or slightly less?
Thanks
Old Feb 22, 2010 | 03:58 PM
Former Sponsor
Thanks
The dyno on our website performed by a customer was with a standard Comptech setup at 6 psi. With increased pressure, I'd expect the gains with your setup to be the same or greater.
regards,
-- Chris
slicko9
May 21, 2010 04:40 PM
deathsled
Dec 8, 2009 08:06 PM
