SOS install
Congrats, but I'm confused at your dyno results. Is your clutch slipping, your down an easy 50whp+ for your boost and blower
I was expecting to see a Mustang dyno. I made 360whp 220trq on the same dyno at 9psi with an old NV1000. And you only hit 350whp becuase of a brief spike at redline likely from a lean out off the limiter, your curve actually only would be in the 335whp range if it weren't for that. Something seriously isn't adding up here.
What is your afr and how many degrees of timing are you pulling? is your clutch slipping? is your aftercooler working properly/AIT all jacked up?
Nope no clutch slipping. The boost is only that high because I have stock headers and stock exhaust with a test pipe. I think there is quite a bit of gain if I got a better flowing exhaust, but I like the sound and look of the stock exhaust. Also the tune is fairly conservative 11.4 to 11.7 afr.
Originally Posted by s2000Junky' timestamp='1327109732' post='21337626
Congrats, but I'm confused at your dyno results. Is your clutch slipping, your down an easy 50whp for your boost
Maybe some others will chime in on this.
Originally Posted by tylek17' timestamp='1327109984' post='21337639
[quote name='s2000Junky' timestamp='1327109732' post='21337626']
[/quote]
I dunno maybe we left something on the plate with the tune.
Originally Posted by s2000Junky' timestamp='1327110640' post='21337675
[quote name='tylek17' timestamp='1327109984' post='21337639']
[/quote]
[/quote]
I hope so. Better that then a sick motor. Your running a higher cfm blower. I would expect to see you touch 400whp at your boost. That is the typical for your set up on this dyno. Who tuned your car?
Power output is what I expected.
Dispite what is advertised, I plan on running an ap2 3.2" pulley and expect about 14lbs with a header and tp with a hair over 400whp. That 400whp status from an ap2 with 3.8"/10psi is bs from what I have seen.
Anywho, how do you like the added power?
