SOS stage 2, only making 110whp gain. HELP!
Old Sep 26, 2013 | 08:42 AM
  #61
s2000Junky's Avatar
Originally Posted by Jmays2k
Damn Junky you a engineer
Hell no... Just too much time on my hands with cars lol
Old Sep 26, 2013 | 09:16 AM
  #62
Jmays2k's Avatar
LOL I understand completely
Old Oct 2, 2013 | 03:55 PM
  #63
McFlurry's Avatar
Had a retune and finally got it to work properly, i guess.
I got 365 for my setup.
I believe output should be a bit higher if I were in a cold country like in some parts of the US.
Power might be lower compared to s2ks with the same setup from the USA because of the high temperature here. My tuner tells me that my intake temperature is a bit high.
Thanks all for your inputs!
Here's my new chart: (My tuner is having a hard time tuning down low, giving me dips and flats.. i dont know why)
updating initial post
Old Oct 2, 2013 | 05:55 PM
  #64
Chulos2k's Avatar
where is your IAT sensor installed?
Old Oct 2, 2013 | 06:40 PM
  #65
s2k manic's Avatar
if your game you might try the aem methanol kit its very hot and humid here in Texas and I made 320 at 8 psi in 100f heat on the old novi 1000 I figure the 1200 at 10 psi would be worth another40-50 hp hope to upgrade next year 365hp sounds pretty good
Old Oct 8, 2013 | 07:25 PM
  #66
McFlurry's Avatar
Sorry for being such a noob. I have no idea where it's installed. Will my tuner where? Or would the installer know? It just so happens that my tuner is different from the installer
I have no idea as to how methanol works here in the PH. Maybe ill try that soon. Thanks for the input.
Im aiming to break the 400whp barrier and planning to put in a 3.6" pulley and upgrade catback from 2.5 to 3." I hope those are enough to hit 400
Old Oct 9, 2013 | 05:57 AM
  #67
bruthaboost's Avatar
If you are sensor is oem, it's in the intake manifold and is known to read slow compared to the GM variant.
Old Oct 9, 2013 | 06:08 AM
  #68
wadzii's Avatar
Banned
air temp corrections are so small that a "fast" or "slow" sensor wont make any difference.
Old Oct 9, 2013 | 06:23 AM
  #69
Good to know.
Old Oct 9, 2013 | 01:27 PM
  #70
McFlurry's Avatar
Yup, sensor's oem. Ill try installing a TS BOV and see of it solves the AIT issue.
