SOS Stage 2 SC
Looking to get $6000obo
FULL KIT
SOS Stage 2 Kit w/ Paxton Novi 1200
SOS 70mm Throttlebody
SOS Upgraded Black Race Heat Exchanger
SOS 3.2" 18psi Pulley
Goodyear Gatorback Belt
SOS 3 Bar Map Sensor
Tial Q 50mm BOV
ID 1000cc Injectors
Walbro 255lph Fuel Pump
AEM EMS Series 2
AEM Wideband O2 Air/Fuel UEGO Gauge
AEM Serial Gauge
I made 441whp 267tq
FULL KIT
Tial Q 50mm BOV
ID 1000cc Injectors
AEM EMS Series 2
AEM Serial Gauge
I made 441whp 267tq
The 10k estimate is spot on. It always seems like you can get it done for 6K or less, but when it is all said and done you will be right at 10k. I bought a used kit for 4500 and still spent 10k when it was all over with tuning and other required parts.
Why not get a Kraftwerks kit good for 400-450whp off moddiction for $4,300 shipped or with tuned aem ems for $5400. Also on s2000 Classifieds on Facebook there is a brand new aem infinity with added harness for $1,400 or a aem v2 for I think $1,100 obo right now. Just make sure you shop it and check out all of your options before purchasing. That price is high and I don't see the benefit of purchasing that "bundle" when you can get a better one for much less.
It will cost you at least $10,000 if you do the labor your self.
Thing you will need
clutch with new oem throwout brearing/pilot bearing and at least an ap1 resurfaced flywheel $700
you will need a gauge pod and since you have aem you might as well get a serial gauge, a defi boost gauge and you need an inline wideband to wire into your ems ($700)
You will also need a , 4 bar map sensor, felex fuel sensor $250
a good flex fuel tune should be about $500-$1000
You can run your stock exhaust but you really should have at least a test pipe
It makes no point since you are buying the kit to not upgrade to the novi 1200 and to the larger heat ex changer.
I also recommend a adjustable fuel pressure regulator so if you run about of injector you can bump the pressure up a litter to compensate.
Thing you will need
I got everything you need just saying......
Everything only has 6000 miles
Driven 1-2x a month to car meets
$6000
Tial Q 50mm BOV
ID 1000cc Injectors
AEM EMS Series 2
AEM Serial Gauge
Competition Clutch Stage 2
Fidanza 8lbs Flywheel
$1000
PuddyMod Stage 2 w/ 4.30 final
$1500
Powerhouse Amuse R1000
$200
Private Label Header
$8000 for everything plus shipping
Or come to my house and I'll install it.
$6000
Tial Q 50mm BOV
ID 1000cc Injectors
AEM EMS Series 2
AEM Serial Gauge
$1000
$1500
$200
