Space in front of AC compressor?
Old Aug 27, 2012 | 07:58 AM
liquidgsr's Avatar
Default Space in front of AC compressor?
Hey I don't have my car where I can take pictures of it until the weekend. Would anybody be able to take pictures or if they have pictures post them up of how much room is available in front of the AC compressor.
I am running into problems getting my dump tube fabbed up. with the KINGS PERFORMANCE manifold I have my OIL Filter Relocation lines running underneath the wastegate and also the oil drain line tapped into the timing chain cover. Normally the dump tube would route through there. I have to find another way to route it now.
H4ard on has his routed to where the AC compressor is, but since im keeping AC he can't route mine there. Any ideas?
Thanks.
Old Aug 27, 2012 | 12:26 PM
S2K-F8's Avatar
Is this what you are looking for?
If you need any other shots let me know.
Scott-
Old Aug 27, 2012 | 12:27 PM
liquidgsr's Avatar
Trying to see if there is space in front of it have the dump tube exit there. Thanks for the picture. Does it look like there space for a dump tube to exit in front of it?
Old Aug 27, 2012 | 12:54 PM
S2K-F8's Avatar
Are you trying to dump them under the car? I don't know man, it's kinda tight with the steering rack, lower rad hose, front subframe
Old Aug 27, 2012 | 01:14 PM
liquidgsr's Avatar
Yea it wouldn't be Safe anywhere else right?
Old Aug 27, 2012 | 01:30 PM
S2K-F8's Avatar
Just went out and took some more measurements. It's pretty tight, you have about 3" of clearance between the serpentine belt and subframe (half way between the crank pulley and ac compressor pulley). The clearance tapers down the closer you get to the ac compressor (less than 2" directly below it).
It might be do-able. I think maybe coming in front of the motor (parallel with the front cross member), doing a 45 degree elbow below the serpentine belt (half way between crank pulley and ac pulley).
What's the outer diameter of the dump tube?
Old Aug 27, 2012 | 02:15 PM
liquidgsr's Avatar
Well its coming off of a 44mm Tial MVR and I don't know where else to dump it. Here is a picture of where the Wastegate sit. Now the problem here is the timing chain cover oil drain and the oil relocation lines running.
looks like im having trouble attaching the picture.
zeroptzero
May 1, 2015 02:23 PM
Moddiction
Jul 21, 2013 07:25 PM
Bad1flip
Oct 23, 2011 11:09 AM
whitebrad25
Dec 3, 2010 05:14 AM
