Spark Plug Opinions
Hi all,
Im after abit of advice from people running superchargers as to whether or not i should be concerned about my spark plugs.
10k NA miles
3K 11psi HKS supercharged miles
Current tune uses conservative timing and AFR of 11.7 when in boost and when cruising i have it mapped to about 14.5. I have no real knock ever register during driving
I also have water injection which operates from 2 psi through to full output at 11 psi.
I'm using the standard spark plugs as i have not encountered any issue with them during running so far.
Reading the following guide
I would say im near normal wear based on what im seeing but its more a grey colour than tan.
Im pretty happy that everything is running well and i have nothing to worry about but its always worth a second opinion. I cant find much information on what effect if any water injection would have to the spark plugs but i know its supposed to have a steam cleaning effect so maybe that would make a large difference to the appearance of the spark plugs.
Thanks in advance for any help you guys can provide!
10k NA miles
