spark plugs
Old Nov 20, 2007 | 10:02 PM
fadiss2k's Avatar
Default spark plugs
Ok, i have NGK 4554 plugs in the s2000 right now, and thats what i had in it when i got it tuned. They are 2 steps colder than stock. I wanted to switch and try out the NGK 3330, but was wondering if it would affect anything since they are only 1 step colder. Would I need a retune if i switch plugs, or would i be ok?
Thanks
Fadi
Old Nov 20, 2007 | 10:38 PM
Kaos_theory's Avatar
wish i could answer. is there any set rule to how much colder you should go based on horsepower?
Old Nov 20, 2007 | 11:34 PM
BlitZs2000's Avatar
There is. I found it once on some spark plug site. Maybe RCs.. Just google it. I think you COULD run a different spark plug without tuning. Just wouldn't be as efficient as the one it was tuned on. Just my noob opinion.
Old Nov 21, 2007 | 05:38 AM
ChefJ's Avatar
I have went with colder plugs on the same map but nevera step hotter. unless you are over 425whp it shouldn't affect anything. How much timing did your tuner pull?
Old Nov 21, 2007 | 07:26 AM
fadiss2k's Avatar
I dont think he pulled anything and thats why my numbers were low i believe. He isnt the best tuner. I run really rich and only made 286 whp on 8 psi with inline pro setup. So i am going to go get a retune somewhere else, but want to get my 3mm headgasket on first. My plugs needed changing though and i have some 3330 laying around and was just wondering if they would be fine to use.
nicholastjs
Mar 19, 2014 08:20 AM
Silver&stoned
15
Jul 15, 2011 12:51 PM
05TurboS2k
Mar 8, 2009 04:21 PM
roi
Dec 30, 2008 02:06 PM
