spool time?
Old May 15, 2008 | 07:46 AM
hondabim's Avatar
Default spool time?
hello turbo heads!
Quick question. If I go for a 2mm or 3mm head gasket, will the spool time/ rpm drop seine you are losing cylinder volume?
thanks
sacha
Old May 15, 2008 | 09:59 AM
AndyFloyd's Avatar
maybe a couple hundred rpm or so, but not too much. Really power off boost is most effected but since a turbo adds power all over the powerband you wouldnt really notice it too much i wouldnt think.
Old May 15, 2008 | 02:13 PM
AusS2000's Avatar
Your gaining cylinder volume. It is the increase in volume versus swept volume that gives you a reduction in compression.
Old May 16, 2008 | 06:31 AM
hondabim's Avatar
sorry, our right, i am a dumb ass
i will gain cyclinder volume, but lose Compression...... thus spool time will decrease," take longer to spool up" more rpm to reach boost peek?
i am starting to do dexterity and what more torque. i am getting a lovefab mini me kit for cody, and using a gt3071r turbo with a 4.56 rick diff.
so, would i need more rpm to reach bost?
thanks for the input, trying to learn!
here is a flick of my last dexterity...
http://youtube.com/watch?v=rW87_ID2csI
http://youtube.com/watch?v=THDp0yCg_PU
Old May 16, 2008 | 12:51 PM
KnowledgeIsPower's Avatar
wow lol nice race
Old May 17, 2008 | 12:29 AM
timg's Avatar
Spool won't change.
You will make less power before the turbo comes on boost. If you don't increase boost, you will also make less power once the turbo spools up.
The big difference is that you can run higher pressure ratios (and make more power).
Tim
Old May 18, 2008 | 09:59 AM
hondabim's Avatar
thanks tim.
so wich one to get, a 2 or 3 inch gasket?
Old May 18, 2008 | 12:42 PM
XclusiveAutosports's Avatar
Originally Posted by hondabim,May 18 2008, 12:59 PM
thanks tim.
DAMN! With a 2 or 3 inch gasket you can boost the crap out of it. Deciding between a 2 or 3mm should come down to what your goals are power wise. What #'s are you trying to hit?
Old May 19, 2008 | 08:16 AM
hondabim's Avatar
i am looking for around 400hp, i want low down toque!!!
i don't want to bogg when i am not on boost...
how much psi can i boost with a 2 mm head gasket? and what hp number should i look for?
thanks
sacha
Old May 19, 2008 | 09:38 AM
slimjim8201's Avatar
Gaining combustion chamber volume, not cylinder volume.
hondabim, go 3mm and boost the crap out of it. Give's more of a safety margin as well.
