Stat sync, car wont start after warm
Old Oct 8, 2007 | 11:28 AM
fadiss2k's Avatar
I havent done any kind of upgrade to the ems.
When it does sit a while, when i hit the throttle a little bit it helps it start, so it might be just the tune.
Old Oct 12, 2007 | 11:56 PM
fadiss2k's Avatar
ok, so is there anything specific i am looking for when i go tot the readout for cranktooth period and t1per??? When i started trying to crank it, a bunch of numbers showed up.
Old Oct 13, 2007 | 06:00 AM
GDM S2K's Avatar
that means there reading the sensor
Old Oct 13, 2007 | 07:03 PM
fadiss2k's Avatar
so does that rule out the crank angle and cam sensor?
Old Oct 16, 2007 | 09:43 AM
fadiss2k's Avatar
??? Also how can i check if its a bad ground/grounds??? Is there another way without following each one?
Old Oct 16, 2007 | 10:02 AM
GDM S2K's Avatar
most of your grounds are gonna be by each headlight under the hood. you will see like a octopus of black ground wires
Old Oct 16, 2007 | 01:03 PM
The Dude Abides's Avatar
I have this same exact issue, I have to let the car run when I get gas otherwise it gets me nervous to try to restart it. Anyone figure this issue out yet?
Old Oct 16, 2007 | 05:43 PM
honda9krpm's Avatar
If your car starts when it is cold then it's unlikely that you have a physical issue (sensors, grounds etc etc). It's likely to be your Fuel enrichment table in the Start setting. Too much or little fuel will cause starting issue. You will need to add or subtract fuel.
Does your sync status goes to ON after a few cranks?
Do you have a wideband?
Does opening the throttle help with the warm start?
Old Oct 16, 2007 | 06:04 PM
fadiss2k's Avatar
1. Stat sync doesnt come on.
2. No.
3. Yes.
Old Oct 16, 2007 | 07:30 PM
mase1's Avatar
your problem lies in the cranking parameters.
