Stock AFR?
Old Oct 23, 2005 | 03:41 AM
MB's Avatar
MB
Member
Default Stock AFR?
Hi,
Ive been doing some data logs from the PLX wideband while the car is still stock, to get an idea of AFR's and knock.
Im getting 14-15 AFR at idle
Im getting 13 at WOT, and then 19 when lifting off the throttle (overrun)
Does that seem ok?
Knock volts at max are 2.2 rising with revs but 2 is a normal high peak.
MB
Old Oct 23, 2005 | 11:01 AM
Wael El-Dasher's Avatar
That seems quite lean compared to my dyno testing before FI. I was getting 12-13 are part throttle and 10-12 at WOT depending on intake temp (thus timing). Best performance seems when timing advance is at 16-18 deg. timing dropped to 12-14 deg. when intake temp was above 130 deg. F.
cheers
W
Old Oct 23, 2005 | 11:58 AM
f20kills's Avatar
Originally Posted by Dark Blue Mark,Oct 23 2005, 05:41 AM
Hi,
Does that seem ok?
MB
This is about what I ran when I was stock for A/F.
Near redline my A/F would be 12ish, 6000rpm to 8000prm it was in 13 range.
Idle was aorund 14.5 and so was part throt.
Wael El-Dasher, is that 16 degrees total timing at redline?
Thas what I run turbo, stock is around 25 degrees
Old Oct 23, 2005 | 12:25 PM
MB's Avatar
MB
Member
Cheers!
Going to buy a new MAP anyway before putting the SC on - just to be catious. I have a distrust for MAP / MAF sensors
MB
Old Oct 23, 2005 | 12:27 PM
MB's Avatar
MB
Member
Where you guys getting timing info from?
MB
Old Oct 23, 2005 | 08:54 PM
folex187's Avatar
So you have your a/f at 12-13 for all partial throttle? I thought you wanted it in the 14-15 range for gradual acceleration.
Old Oct 25, 2005 | 01:11 PM
MB's Avatar
MB
Member
My partial throttle is between 14 and 15, more rapid up and down than idle as you would expect.
I get quite a dip in AFR at peak revs (8900)
Starts dropping from 13 at 8000rpm to 11.1 at redline. Is this normal?
MAP volts are flat at 2.8 but dip to 2.37 at redline so that does seem to be failing?
Advice!
MB
Greg W
Jun 25, 2014 09:52 AM
s2k-jn
Feb 23, 2014 04:53 PM
soulsweeper
19
Jul 16, 2012 08:43 AM
s2konroids
Aug 4, 2010 02:15 PM
