Storing the S2k for 3 months
Old Sep 27, 2009 | 10:14 AM
azride1983's Avatar
Default Storing the S2k for 3 months
hey guys i'll be leaving out of country for 3 months worth and i'm just wondering if the car would be ok without using it for that long? will it start without problems after 3 months of no use? i'm worried of the oil drying up in the cylinders or drying up the sc turbine? this the first time i'm not going to use it for that long..thanks..
Old Sep 27, 2009 | 10:29 AM
neeman77's Avatar
Just fill up the gas tank so no moisture forms in the tank, pump up the tires to 40 psi. The oil will not dry up in the cylinders/supercharger. You are fine. When I am awakening my car from its slumber I usually change the oil and then crank the engine over until it gets oil pressure with the fuel pump fuse out. Then it should be good to go.
Old Sep 27, 2009 | 12:19 PM
azride1983's Avatar
thanks ...thats good to know.. i'll do all that before i leave..
bikky
Sep 3, 2014 07:35 AM
stan2k
Jul 28, 2014 08:54 AM
mikey k
Jan 20, 2010 09:58 PM
kingbriani
Jun 18, 2008 09:25 PM
jojipoji
Mar 16, 2004 06:46 PM
