Studs without removing head ?
I have a goal of 600 on e85.
I have a motor with 25k on it. No issues.
Is it possible to pull one at a time and torque 1 at a time in sequence without removing the head ? It's clearly a lot more work removing the head and want to know the success rate of people using this method. I've heard of it working. But want the experts .02
I do realize its a used HG but hey I might as well ask. But I've also heard of some stock head bolts holding 600 and of some not. So.
Realstreet ran over 800hp for a long time on an uncracked block with stock studs. It eventually lifted just enough to pop a freeze plug, but nothing serious. The F-20 is very capable in stock form aside from the stock retainers. If you do replace the studs I wouldn't replace with a thicker head gasket as mentioned above. OEM gasket is plenty strong and having stronger studs just gives you extra security.
I thought they had studs ??
