Studs without removing head ?
Old Jul 20, 2012 | 10:13 AM
s2klariat's Avatar
Not that I'm aware of. Pretty sure it was an unopened block. They just had Ferrea springs, retainers and Brian Crower cams. I could be wrong though, someone correct me if I am.
Old Jul 20, 2012 | 11:11 AM
Shftat9k's Avatar
Real street did have ARP headstuds aswell as valve train upgraded with cams. I made 621whp on a completely stock motor. I don't think there is an exact number when the head will lift.
Old Jul 20, 2012 | 11:31 AM
s2klariat's Avatar
I stand corrected. Either way, I'm sure he'd be safe atleast for a good while on the stock studs. His engine supposedly only has 25k on it. Barely even broken in IMO, after all, it is a Honda
Old Jul 21, 2012 | 08:55 AM
jpetch05's Avatar
Anyone else around 600 on headbolts ?
Old Jul 21, 2012 | 09:38 AM
TerminatioN's Avatar
I'm 99.9% sure RealStreet didn't have aftermarket headstuds when they were running the stock block. (Proof)
More...
Conclusion: Nothing actually broke. No cracked sleeves, no damaged pistons, A freeze plug popped out of the head and pushed coolant into the valve cover (and out of the breather). The Pistons, Rods, Bearings, Sleeves, Block, Rings, everything was undamaged. It appears the prolonged high cylinder pressure exeeded the clamping force of the original stock head bolts and lifted the head, pressurizing the cooling system and popping out the freeze plug. All the engine needed was a freeze plug popped back in, and go back at it.
From here: https://www.s2ki.com/s2000/topic/938...esults-inside/
So basically after prolonged exposure to 31psi (and lots of time with a little lower than that) is when the stock headstuds finally gave out for them.
Old Jul 21, 2012 | 11:35 AM
Shftat9k's Avatar
Sorry guys thought they were on ARPs for some reason.
Old Jul 21, 2012 | 01:53 PM
Kitesurfer s2000's Avatar
God i need mase over in the uk so he can max my little gt3076 out .All the sc guys over here are boosting to 18psi stock motor and hitting 500whp ish ,need more power lol.
Old Sep 25, 2013 | 07:42 AM
ROFLv8's Avatar
I am at 600hp 22lbs c16 on stock head stock block stock studs if that helps any???
ROFLv8's Avatar
80k miles
Old Sep 25, 2013 | 08:35 AM
Still stock 22 psi pump fuel gt30 :-)
