Stupid question...
Old May 19, 2011 | 12:19 PM
jsenclosure's Avatar
Default Stupid question...
Can you swap out a Ap2 ECU with the Ap1 Ecu and then use a hondata flashpro to tune it? I assume no but damn, the hondata k-pro is pricy at 2100- with the sensors needed, and i need obd2 here in NY for inspection. Do i have any other options? i know emanage and aem are not obd2 compliant and will not pass nys inspection
Old May 19, 2011 | 12:31 PM
s2000442's Avatar
I believe you can use haltech and pass obd2. Not sure about other question but I assume no otherwise people would have done it by now.
Old May 19, 2011 | 01:18 PM
sunman's Avatar
simple answer is no. You can't swap in a dbw ap2 ecu to run flashpro without spending a ton of money on the other things necessary. ( I looked into this at one point.)
as far as i know, the only option is kpro to keep obd2 for MY00-05. All other standalones (inculding haltech) will not be obd2 compliant. I think you are referring to the dual ecu harness that Evans may or may not be releasing.
Old May 20, 2011 | 10:54 AM
DFWs2k's Avatar
You can be obdii compliant w haltech, call evans, great shop and great prices
Old May 20, 2011 | 11:46 AM
Deception's Avatar
Im not recommending E-Manage, but FYI it will not interfere with OBD2 for inspection.
Old May 20, 2011 | 12:24 PM
sunman's Avatar
I didn't think the Haltech was obd2 compliant without the use of the dual harness that may/may not be released.
Old May 20, 2011 | 03:18 PM
itlynstalyn's Avatar
I'm pretty sure Evans already has a haltech harness. I've been begging him to do the same for the AEM EMS so I can be OBDII compliant. My car would pass the sniffer with flying colors on E85.
bruceski
Sep 15, 2014 10:39 PM
taiphon
Mar 31, 2010 05:17 PM
drhess06259
Dec 6, 2009 02:30 PM
Jimboner
Aug 24, 2009 08:28 AM
ebbai
May 18, 2008 10:02 AM
