Super easy crank pulley bolt removal
Old Oct 22, 2012 | 05:59 AM
  #21
liquidgsr's Avatar
yeah I couldn't turn it on. So I took a heat gun and heated up the bolt, then used the compressed air can like you suggested to cool it down and it came off pretty easily.
Old Oct 22, 2012 | 06:07 AM
  #22
Gernby's Avatar
Former Sponsor
Originally Posted by illestrolla
1: NEVER use a torque wrench to loosen ANYTHING. This is what breaker bars are for
I agree that you should never use a torque wrench as a breaker bar, but I don't believe there is anything wrong with using a torque wrench to loosen a bolt. Basically, if the bolt isn't seized, and will loosen without exceeding the max rated torque of the wrench, then it shouldn't be hard on it.
Old Oct 22, 2012 | 09:10 PM
  #23
Excalibur's Avatar
Originally Posted by RedSunS2K
This is good advice, but I would advise against using an actual torque wrench to loosen any type of bolt! My torque wrench box says to never use torque wrench to break loose bolts, only tighten. Doing so may cause the torque wrench to malfunction. Use a breaker bar instead.
Otherwise good info!
This is 100% correct.
Old Nov 8, 2012 | 08:30 PM
  #24
kerm1t's Avatar
Originally Posted by Gernby
I discovered this trick years ago, but recently used it to remove my crank pulley bolt. All you need is a can of high pressure compressed air, like this, and a torque wrench. Go for a drive to get the engine up to normal operating temperature, then park the car with the transmission in a high gear and put the parking brake on. Immediately spray the crank pulley bolt for ~20 seconds with the spray can turned upside down until you see ice forming on the bolt (like this). Immediately get the torque wrench, and remove the bolt. It should loosen almost as easily as a lug nut.
Is it necessary to put it in high gear? Can u do it in neutral?
Old Nov 9, 2012 | 05:43 AM
  #25
spets's Avatar
You need it in gear to keep the engine crank from spinning.
Old Nov 9, 2012 | 09:51 AM
  #26
kerm1t's Avatar
ah.. ok. can someone tell me what size is the crank pulley, and how much to re torque the new one?
Old Nov 9, 2012 | 01:00 PM
  #27
RedSunS2K's Avatar
Not sure the size. But torque specs from the service manual says 181 ft lbs.
Old Nov 10, 2012 | 09:20 PM
  #28
S2000 Cabrio's Avatar
its a 1/2 drive x 19mm deep socket 6 point.
Old Nov 11, 2012 | 02:27 PM
  #29
kerm1t's Avatar
so this would be if you dont have the crank pulley tool, right?
Old Nov 12, 2012 | 12:44 PM
  #30
Jeremiah's Avatar
^Bingo.
