Supercharged and BOV need help
Old Nov 30, 2014 | 10:09 PM
amdaman's Avatar
Default Supercharged and BOV need help
Hi guys,
I've bought a PLM intercooler for my comptech supercharger setup which will be running low boost (4.25 pulley). The piping has a HKS BOV mount on it, my question is will the BOV that comes with the comptech fit this? If not should I get an adaptor or just buy a HKS BOV or something? I have no idea what to buy or what to do. I'm not bothered about the sound, if I can blank it I will.
Any advice appreciated
Thanks
Old Dec 1, 2014 | 04:51 AM
Sylvain2000's Avatar
No , the CT bov won't fit
I have a hks bov ssqv 4 like new if you want a used one lmk
Old Dec 1, 2014 | 05:55 AM
CoolGuy094's Avatar
Someone might make an adapter that would adapt your HKS flange to a 1" port that you could plumb to the stock Comptech BPV.
Old Dec 1, 2014 | 11:45 AM
amdaman's Avatar
PM me about the HKS - i'll see if its in budget.
Is there a standard flange name for the comptech flange or is it just a 1" port? Does it plumb back into the air intake elbow?
cheers
Old Dec 1, 2014 | 12:06 PM
AE_Racer's Avatar
The comptech bypass valve doesn't mount like the greddy flange on your piping. It has a 1" hose that runs to the bypass valve on the boost side and is routed back into the intake side via another 1" hose, or if you prefer can be vented to atmosphere.
Old Dec 1, 2014 | 01:40 PM
amdaman's Avatar
Cheers -
So do i need something like this?
http://www.ebay.co.uk/itm/25mm-1-HKS...item4ad6001ec3
Then I can use the 1 inch hoses?
Old Dec 1, 2014 | 02:12 PM
amdaman's Avatar
or maybe this?
http://www.ebay.com/itm/181599635726...witem=&vxp=mtr
Old Dec 1, 2014 | 03:52 PM
AE_Racer's Avatar
You have the right idea but those are all to mount different blow off valves. You basically just need a piece of 1" aluminum piping long enough to get a hose and clamp on and have it welded on. You may be able to do that over the existing flange, would have to see it. Perhaps the easiest solution would be to buy the correct bov for the flange you already have.
Old Dec 1, 2014 | 11:58 PM
amdaman's Avatar
I think someone mentioned the stock comptech one was 1"? Here's a picture of the pipe in question, it has some other fittings too.. Are they for stock vac tubes?
Old Dec 2, 2014 | 03:10 AM
CoolGuy094's Avatar
One of those is for the air pump which should be a 3/4" port. I'm not sure what the other one is. What size are both of those?
