Supercharger Boost Question
Old Jan 24, 2005 | 09:03 AM
jdmdohcpower's Avatar
Default Supercharger Boost Question
I have the Comptec SC with stock pulley. I want to upgrade the to the 7lb pulley. Is this going to be too much for the engine. I dont want to blow it nor do I want to change the pistons to lower the compression.
Old Jan 24, 2005 | 09:21 AM
revhi's Avatar
We have a FI section now.
Old Jan 24, 2005 | 09:24 AM
xviper's Avatar
Moving to F.I. now.
Old Jan 24, 2005 | 10:56 AM
Thanks for the move.
Old Jan 24, 2005 | 10:58 AM
revhi's Avatar
Youll be fine, just dyno it and turn up the FPR. Thats what Im running right now.
Old Jan 24, 2005 | 11:02 AM
Do I need new spring or anything inside the FPR? I think dyno tunning is out of the question becuase there is no one near me that does it. It is my everyday car and I dont want any issues that may effect reliability down the road. How long have you had the 7lb pulley?
Old Jan 24, 2005 | 11:10 AM
revhi's Avatar
The FPR can just be turned with a allen key, but you need a way to see you air/fuel. Maybe a wide band. I drove 2 hours to my dyno. Most people running higher boost also have a aftercooler. If done right, reliability is fine. Dosent sound like you have the right tuners around you to do this.
Old Jan 24, 2005 | 11:16 AM
I dont think so either. I would make the drive but will dont have the a/c so I have that on my list to. I have an air fuel guage. Do you think it can be street tuned. I can just adjust the fuel to make the gauge read the same as it does now?
Old Jan 24, 2005 | 11:18 AM
revhi's Avatar
No its not accurate enough at all. Get an aftercooler instead.
Old Jan 25, 2005 | 08:01 AM
S2000RAT's Avatar
Don't run the 7 PSI pulley WITHOUT the AC.
RAT
