Supercharger question
Originally Posted by johninator,May 11 2005, 09:50 AM
Since your mind is set in having boost at lower RPMs and keep it steady to 8psi then you should just go with the turbo kit. Why bother with all these questions when the solution is already done. You are trying to retrofit a kit that is not designed to do this.
Some guy recommended the HKS blowoff valve that can vent through boost. Or using a boost controller, vacum canister and a check valve to fool the blowoff valve could be tried.
Get a normal FI in your car first then decide whats next. By the way, torque is what you feel directly not HP.
I don't want to light up tires @ 2000rpm, I just don't want to go higher than 8psi but like the idea of a smaller pulley.
Jakub-
Anyone in your area that has a SC S2K? Go test drive one and see if you like it. The advantage with our SC is you can drive the car normal and feels just like stock. You might can go with a small turbo set at low boost 5-6lb. You'll have plenty of torque down low and won't be too hard on the engine.
Just go ahead and get the 9lb. pulley for the SC. You might build up more torque down low than a smaller pulley. If you don't want to reach the full 9lbs to make your engine last longer, just don't rev to 9000rpm.
My car hauls ass by the way.
Originally Posted by OyATL,May 11 2005, 06:46 PM
Jakub-
the reason why I will go SC is that when I cruise on the highway I am at 5500rpm (4.57 gears)..in this RPM range, the smaller turbo would be at full boost already. I would like to avoid this. The only way would be to have a boost controler, but I have no idea if this will work on the available turbo kits out there. I have dropped the idea of going turbo, the Vortech looks like it simply belongs there (if you know what I mean)
Back to my idea...I heard of some company from UK that has some sort of "boost release valve" that will release the boost at a set level.
Talking about not reving it to 9k...r u crazy?
blink962
May 23, 2013 10:46 AM
m777erlin
Aug 7, 2003 06:28 PM
