supercharger Smogging
How fast (exactly) is 365whp out of CTSC?
I'm stock on 5.5psi w/o A/C and probably around 265whp, I've got 4.57's and short of built muscle cars there's not a whole lot that messes with me anymore...
Just ordered the A/C kit, and then EMS and Injectors next... What would be limiting factors for running 13psi pulley @ 9000? (Other than lower CR) I.e. Does anything over 11psi __require__ headwork / intake porting / etc?
"How fast (exactly) is 365whp out of CTSC?" not really sure what you mean..do you mean top speed or quarter mile? I dont really drag it so im not sure about the quarter times...
as far as 13 lbs of boost goes....after 11 (some people say 10) you should to do a gasket or headwork to lower compression...
I like the stock gearing but it would be intresting to see what gears and ctsc does for you...
Good luck getting that kind of power from a Comptech. This is why I am ditching the CTS/C for a turbo set-up. Your probably going to want to drop the compression by installing a 2-3mm headgasket (if you can even get close to that kind of power), remember maximum efficiency on the Comptech is 55,000 rpm's (yes, there is a little fudge factor). From what I have read here the Vortech is the only one able to exeed 400whp.
Why does everyone say this? The Comptech unit uses a Paxton Novi 1000 supercharger. It is capable of a max flow of 940CFM.
http://www.paxtonauto.com/superchargers_novi_1000.html
The Vortech unit is capable of 1000CFM:
http://www.vortechsuperchargers.com/products/units/
with a max impeller speed of 53,000rpm (meaning that if you're specs on the Comptech are correct than it's actually capable of a bit more rpm)
Can someone negate this with some concrete evidence?
