supercharger squeel
Old Oct 3, 2006 | 08:11 AM
djpeak10's Avatar
Default supercharger squeel
Ok guys I am going to try and explain this the best I can. I am vortech supercharged, and this morning when I started my car there was a noise coming from the engine bay. So I popped the hood and It sounded like a hampster wheel that has a creek in it every time it makes a revolution, and it sounded like it was coming from the actual blower. This has happened twice before but has gone away the next day.
So I am not sure if the belt needs to be tightened or what, I dont have a boost guage so i cant see if I am loosing boost. Has anyone experienced anything like this or have an Idea what it could be? I was going to make a video of it the last time it was making that noise it went away anyways thanks in advance
Old Oct 3, 2006 | 11:16 AM
xviper's Avatar
You can test the belt for the correct tightness. Grab it in the middle between 2 convenient pulleys (that you can reach) and try to twist it 90 degrees. If you can do it easily, you need it tightened.
You main shaft bearing could also be going.
Old Oct 3, 2006 | 11:20 AM
Enthralled's Avatar
I'm guessing the bearing is gonna go soon....
Old Oct 3, 2006 | 12:10 PM
djpeak10's Avatar
what happens when your bearing goes?
Old Oct 3, 2006 | 12:13 PM
djpeak10's Avatar
and if i did need to send it to vortech the whole unit would have to come out and the car would be undrivable right?
Old Oct 3, 2006 | 02:09 PM
John_Z's Avatar
Have you recently washed your car or engine bay? Sometimes I'll hear a squeal coming from some pulley under the hood after I wash the car. After the car has been running for awhile it goes away.
Old Oct 3, 2006 | 02:10 PM
John_Z's Avatar
When you rev the motor you'll see the blower output shaft move in and out.
Old Oct 3, 2006 | 02:55 PM
djpeak10's Avatar
please explain john what is the output shaft?
Old Oct 3, 2006 | 03:19 PM
John_Z's Avatar
It's the shaft your Vortech pulley is connected to. It's between the front of your valve cover and blower unit.
watchdogd
Dec 30, 2019 10:22 AM
blue monster
Jan 29, 2016 05:37 AM
LowlyGent700
Jul 2, 2014 07:03 PM
kaissi
Nov 14, 2011 09:28 AM
s2konroids
Feb 8, 2011 01:42 PM
