Supercharger with torque
Old Dec 27, 2017 | 06:32 AM
Sideways's Avatar
You make the crank pulley extend out 0.281 and the supercharger pulley extend out 0.281. Because the pulleys are extending different directions you need 0.56 movement on the supercharger to line up the pulleys.
Old Dec 29, 2017 | 09:21 AM
E4RTH WORM JIM's Avatar
I bet the intake temps were hotter than the surface of the sun though right?.....
You running meth to cool it down?
Old Dec 29, 2017 | 01:18 PM
s2000Junky's Avatar
Not necessarily, if the blower is sized appropriately for the duty/ IE speed/boost. Which based on Sideways explanation of this upgraded blower, it is - being more efficient in the operating range being run. That means cooler IAT.
I like water/meth injection, but with a low comp engine with a good IAT, its not always required to be safe. It is pretty incredible that this set up is being run on strait 91oct, if I recall accurately?
Old Dec 30, 2017 | 07:16 AM
Sideways's Avatar
Actually it was pinging on 91 and I ended up using 95 octane.
Old Dec 30, 2017 | 09:10 AM
AP1Chief's Avatar
Pretty sick man! mad props!
Old Dec 30, 2017 | 11:22 AM
s2000Junky's Avatar
That's not surprising at all, considering what your yielding currently, but I hadn't heard different so thanks for clarifying.
Old Dec 30, 2017 | 11:45 AM
Orleansjunky's Avatar
needs to be a kit. but there would be a lot less S's on the street. mad power good job
Old Dec 31, 2017 | 01:09 PM
Do you have any AIT logs or data, I’d be very interested to see what they are like during a WOT pull.
Old Jan 10, 2018 | 12:51 PM
Lex's Avatar
Lex
Impressive! Good job!
Old Jan 10, 2018 | 10:07 PM
Dreaming_S2k's Avatar
Would it even be worth going to a setup like this for target boost levels around 15-16psi?
I've got a 3.2" ASP pulley on my v2 right now and I'm only making ~10-11psi at 8600rpm on F22.
