Supercharger with torque
Old Jan 10, 2018 | 10:42 PM
  #21
s2000Junky's Avatar
Originally Posted by Dreaming_S2k
Would it even be worth going to a setup like this for target boost levels around 15-16psi?
I've got a 3.2" ASP pulley on my v2 right now and I'm only making ~10-11psi at 8600rpm on F22.
How are you only seeing 10-11 psi on a 3.2" pulley? Isn't this about 5-6psi short on a VT kit with the supplied larger 6" size crank pulley?
Old Jan 11, 2018 | 08:29 AM
  #22
Dreaming_S2k's Avatar
Honestly.... I have no idea. We checked for boost leaks everywhere, only found one on my original tuning day and we fixed that. It's 100% a 3.2" pulley though, and the belt is not slipping at all from what we can tell. It's a standard V2 SCi kit for 04-05 that I retrofitted onto my 07 (basically deleted the FMU).
I'm after more boost without going overboard, but I also want to go air/air intercooler. I figured with the pressure drop that I've heard goes with going air/air, this SC might be a good trade out to help me get where I want to be.
Old Jan 12, 2018 | 04:20 PM
  #23
soulicious's Avatar
If I recall correctly, the SCi has the same internals and compressor map as the N1220. If that’s the case, then his boost level is inline.
Old Jan 12, 2018 | 04:28 PM
  #24
s2000Junky's Avatar
Its the crank pulley diameter difference in this case, not the blower. The VT kit has a larger pulley. 6" vs 5.45".
Old Jan 12, 2018 | 05:39 PM
  #25
soulicious's Avatar
I get that. He’s at 55k-ish blower rpms at peak. With a Si/N1200, the boost level would be higher. I had the n1220 and n1200 in my previous setups.
Old Jan 12, 2018 | 07:40 PM
  #26
s2000Junky's Avatar
Hmmm When I ran the Novi1000/1220 - same) and a NV1200 with the 3.2" I made 14psi at 9k with the NV1000 and 17psi with the 1200 in the summer on a low 9.6:1 comp engine, and saw 2 psi higher then that in winter temps. That's on a smaller 5.45 crank pulley as well. It should be a good 3-4psi higher with the 6" vortech crank pulley. 10psi with a 3.2 at 8k isn't consistent with my experience and from what ive seen other post over the years. Hell I made that with a 3.6" so i dont know.
Old Jan 12, 2018 | 08:34 PM
  #27
soulicious's Avatar
Oh, I saw Intercooler and thought pressure loss. I need to read the post fully. I found this
https://www.s2ki.com/forums/s2000-fo...o-tune-734359/
Old Jan 12, 2018 | 11:57 PM
  #28
s2000Junky's Avatar
Fmic would be the easy explanation, but no, he is running standard air/water.
Old Jan 13, 2018 | 09:09 PM
  #29
Yeah I'm air/water now, but I'd kinda like to run air/air. I feel like I experience a fair amount of heat soak with the air/water setup now in high summer. I'd really like to run ~14-15psi though with an air/air setup.
Which was why I was asking if this supercharger would make sense as an upgrade.
Old Jan 14, 2018 | 12:44 AM
  #30
s2000Junky's Avatar
You think you have boost loss now lol I think a water/meth injection kit would be a lot less expensive. get the most out of what you have now for a few hundred. If that still doesn't suffice, then explore this avenue.
stantaur
Mar 19, 2008 08:18 PM
gilbertg
Apr 7, 2005 07:02 AM
Sideways
Jan 27, 2004 02:32 AM
jelliotlevy
Dec 30, 2003 04:19 PM
