Supercharger with Vertical Intercooler
Old Sep 21, 2010 | 04:52 PM
rikhemi's Avatar
Default Supercharger with Vertical Intercooler
Wondering if anyone runs a custom intercooler wither behind the radiator or vertically since we have the space to prevent boost loss. I have read the FMIC lose around 3-4 psi which is outrageous in my opinion.
If you have any setup like this, please post pics.
Thanks,
Old Sep 22, 2010 | 10:55 AM
Seattle2k's Avatar
Are you referring to a "v-mounted" intercooler? If so, there are several on here who have done it. There's even a setup for sale in the classifieds here.
Old Sep 22, 2010 | 12:45 PM
rikhemi's Avatar
I see a FMIC one here but I was wondering if there was one like a subaru sti or something with less piping.
Old Sep 22, 2010 | 09:44 PM
305s2k's Avatar
I dont believe you can't fit a v mount setup with a big ol' supercharger slapped in front of the motor. I could be wrong, but I dont see it fitting.
Old Sep 23, 2010 | 04:32 AM
rikhemi's Avatar
Is there any way to minimize the loss in a FMIC?
Also, would there any big negative effects making a custom FMIC behind the radiator to minimize the piping? I know the cooling wouldn't be as much compared to the front of the car but the PSI loss can make up for it.
Im just looking for an alternative to an aftercooler since you dont see them selling much here seperately and new cost over 1k.
Old Sep 23, 2010 | 06:18 AM
SRap1's Avatar
its not really the piping that causes alot of pressure loss, its the intercooler. the best way to minimize pressure loss is less bends, and a properly sized intercooler.
Old Sep 23, 2010 | 06:51 AM
rikhemi's Avatar
Makes sense.. So would it be beneficial just to get a custom intercooler with some smaller specs than the one used by some of the vendors here to get a psi loss of around 1-2. I have a local shop here that does mandrel bends so that should smoothen out the piping.
Old Sep 23, 2010 | 07:13 AM
MugenRioS2k's Avatar
yes down flow vs cross flow
down flow has increased cross section area flow area and slightly more surface area.
However there is a point of diminishing returns.
If the surface area is to large and the wall friction increases and becomes a problem; then there will be a reduction in flow velocity leading to a larger pressure differential between inlet and outlet resulting in less mass flow to the motor and therefore less power.
Flow velocity is an aspect of forced induction ( and NA) that is over looked.
Larger piping/intercooler is not always better.
Old Sep 23, 2010 | 07:29 AM
rikhemi's Avatar
Anyone here built their own custom intercooler.. If so how much was the final cost and psi lost in daily driving since I heard the dyno pull is misleading in regards to psi loss.
CoolGuy094
Jul 28, 2017 10:39 AM
Monacos2k
Jun 2, 2014 08:58 AM
o'malley_808
Jan 26, 2012 12:03 PM
boosted4dr
Forced Induction For Sale
42
Oct 7, 2010 04:32 PM
gusrock77
Jan 22, 2006 04:27 PM
